Can I glue the home button to the metal bracket? Will it function?
Reason why I want to do this, is because I dont have a lot of money to spend on a replacement screen and have actually been burned on a cheap £25 one, which has terrible ghosting/motion blur and also has phantom touches after some use, the seller has refunded me 30% and let me keep the screen so theres that.
But I am so annoyed and frustrated by these issues that I'm strongly considering going back to my old screen, which while cracked and missing glass around the home button (allowing it to move and pull up out of its space) worked fine and had no screen/digitizer damage.
This is why I want to know if I can safely super glue the home button to its metal bracket, either directly gluing the center back of the button, or the gasket, or both, whichever will work best and keep the button secure, Ill be putting a glass screen protector on the screen as well which could help keep it aligned/show me when its coming away.
Would this work? and would the button be damaged in the process? I do have a spare button that I can use to test, but if it wont work Id rather find out first.
Es esta una buena pregunta?
3 comentarios
I agree with Alex about using superglue. When drying it generates some gas that makes glass blury. I would suggest that you send your damage screen to a dedicated shop to have the front glass changed. In europe it is around 20€ to get a clean repair with keeping the original apple lcd quality
- de philippe
use packing tape. Packing tape works fine with capacitive touch, and as long as the sensor is sparkly clean, the print will transfer through
- de Scott
philippe gas cannot get between the glass and the lcd to make it blurry as its sealed by either loca glue or oca laminate
- de daniel
