Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Audi Q7 turned off and wont crank
Hello short story i was driving normaly took a turn and then steering wheel got heavy the car turned off, messages appear in the screen saying alternator not charging the batterie, eps malfuntion, gearbox limited , and the car wont even crank all accesorys worked but they where dimming so i replace the battery but nothing any tips?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
it was the ecu got water damage dont know how but it did
Fue útil esta respuesta?
Puntuación 0
3 comentarios:
How did u find out it was your ecu?
- de
ecu is on the passanger side open the hood and under the wiper blade there is a black cover
- de
Life saver!!!!!!!
- de
Respuesta Más Útil
Following are the common solutions to kickstart your Audi Q7 once again:
- Battery Replacement
- Fuel Pump Replacement
- Ignition Switch Replacement (Electrical)
- Ignition Lock Cylinder Replacement
- Starter Replacement
- Camshaft Position Sensor Replacement
- Crankshaft Position Sensor Replacement
- No Start Diagnosis
Puntuación 1
1 comentario:
after having accident (a crash) with my Q7 it stop and didnt crank again. any solution?
- de
Añadir tu respuesta
carlos estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 25
Ultimos 30 días: 73
Todo El Tiempo: 4,430
