Saltar al contenido principal
La segunda generación (modelo de chasis L30) era una versión exclusiva para el mercado estadounidense, nuevamente diseñada por el centro de diseño de Nissan en California bajo Doug Wilson hasta 1994 (congelación del diseño en 1995).
Preguntas 9 Ver todo
How do I install an ac compressor?
How how do I install an AC compressor on my 2000 Nissan Altima. I have never done it before so I need a step by step tutorial
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
there is special equipment needed to do an air conditioning compressor unit. the tools required will make it a job best left to a professional or at least someone with the tools . installing the pump is simply a matter of removing the bolets holding it on and putting the new one in also removing the to hoses and electrical connectors. thats the easy part once you put it together you have to purge the system of moisture by pumping out the air so you will need a vacuum pump . you will also need to replace the condenser. whenever you open a air conditioning system you need to replace this . Once youve purged the moisture you need to test to see that theres no leaks in the system and only then if theres no leaks will you be able to put the freon into the system . This is a very informative video
https://www.youtube.com/watch?v=95RdGLFI...
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Monique l estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 1,829
