Xbox One X wifi/bluetooth removal
Before i jump at buying the X, can anyone answer whether I can remove the internal wireless chips on the console to play with wired net and pad? This is possible with the Xbone, wondering if anyone who has voided their warranty could test it for me?
If possible i'd like to know if it's just the wifi chip on the side needing removal or the front chip too.
Please don't respond with the console emits rf inside etc or why microwave pulse is harmless, that's not the response im looking for. Thanks
-C
Es esta una buena pregunta?
3 comentarios
Bump I'd like to know as well
- de Dave Davis
Ok, went out on a limb and just did it. Remove the two wireless cards and you can still run your xbox with a wired controller. No IR or power switch turn on, so you will have to turn on with the wired controller. I'm EMF sensitive and this did the trick.
- de Dave Davis
Hey Chris, in the original Xbox One you have remove wifi board and the front panel? I have remove only the upper wifi chip and disconect the antenna. Its nessesery remove also and the front panel for zero emissions?
- de Spiros
