Keurig shuts off right after I press brew, and the menu option is dead
OK OK I bought it at a thrift store BUT it is really clean, someone took care of it. I would feel great if I can resurrect this baby before surrrendering it to electronic waste.
Es esta una buena pregunta?
4 comentarios
My k supreme smart keurig id pot comes on add kcup shut lid starts then stops and shuts off. Anyone know
- de Jaimefrog
Thank you all for your solutions! I had a similar problem with the machine turning off. I brewed a first cup but when I tried to brew a second cup, it would shut off. I disconnected it and reconnected it several times but the issue persisted. Then luckily I found this blog and followed several posted answers to fix my problem. I removed the reservoir, took the Keurig to the sink turned it upside down, tapped it a few times, let the residual water drain, turned it right side up, cleaned the needle and put the reservoir back. I connected the machine, set it up for a brew, waited till the water stopped heating, pressed the brew button and bingo it worked. Thanks again everyone.
- de Hilda Franco
After pushing the power button, green for a few seconds, the red descale light comes on, then everything shuts down.
How do you descale? Several years ago I used whatever solution Keurig sold me. Took me 2-3 weeks to get rid of the terrible taste. Said I would never to that again.
So please, a simple means to descale. I love my Keurig and want to get it working asap.
Thanks
- de Jim Bruner
Had a similar issue with a machine at work—turned out to be buildup inside the brew head. I also started looking into alternative coffee setups and found this helpful resource: https://brewmenuus.com/ for menu ideas and comparisons. Might be worth exploring if you're considering switching things up.
- de 7brew menu
