Saltar al contenido principal
The Essential Phone is Essential's first-generation smartphone, released in August 2017. It is available in black moon, stellar white, stellar grey, and ocean depth colors.
Preguntas 11 Ver todo
SIM Card not recognized after drop
I dropped my phone last night, and now it thinks it doesn't have a sim card. How can I fix this? I've tried restarting it, but it cannot make calls, texts, or go online.
Es esta una buena pregunta?
Puntuación 4
2 comentarios
Actually, the ejectable sim tray had popped out part way and hadn't seated properly shut again. Problem solved!
- de
Dropped my phone and was super bummed . Came across this and it worked . You’re a life saver brotha , good thinking . Thanks G 🤙🏽
- de
Agregar un comentario
3 Respuestas
Solución Elegida
if the sim card is not reading, there is a high likelyhood something got damaged in the drop. either the sim reader itself, or, more likely, the logic circuit for the sim reader.
if you replace the sim tray, and it doesnt fix the issue, then the logic circuit is failing, and that would need to go.
Fue útil esta respuesta?
Puntuación 3
Respuesta Más Útil
I solved this same issue, this might work for you too. Shut off your phone. Pop out the SIM card and place it on a thick piece of paper, use an exacto-knike to cut an outline of the SIM card on the paper. You can also draw an outline with a pen/pencil of the SIM and cut the outline. Try to be as precise as possible and dont exceed the outline, trim excess if needed. Then place the paper cutout in the SIM tray, place the SIM above the cutout on the SIM tray and pop it back in. Turn on your phone and you should get signal. If the SIM cant be popped back in, use a thinner paper, likewise, if this solution doesn’t work, test it out with a thicker paper/multiple layers of thin paper.
Puntuación 18
19 comentarios:
Worked for me perfectly !! Many thanks !’
- de
Like which side should the paper be on the gold side or white side with numbers
- de
It works again thanks so much :)
- de
Wow. This actually worked. However, the way this is written implies you put the paper below the sim card in the tray. doing that you're blocking the contact points. the paper goes ABOVE the sim card, I assume this presses it down further. Thanks for this tip, though. Saved me a thousand bucks for now.
- de
This worked on my iPhone 13! Amazed! Paper goes on bottom of sim card on iPhone.
- de
Mostrar 14 comentarios más
i just wiggle my sim card in and out and continue to turn my phone on and off
Puntuación 2
1 comentario:
This worked for me - brilliant
- de
Añadir tu respuesta
Emily estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 106
Ultimos 7 días: 695
Ultimos 30 días: 3,220
Todo El Tiempo: 71,280
