White Vertical Lines on the screen
My iPad was given to me last summer of 2014. Today, its been 3 years and still alive. No dents, or even a crack. But then last month when I woke up, the screen of my iPad just had some vertical white lines all over the screen! I don't know what to do. It just doesn't go away. When I use it in full brightness then make the iPad so hot, I lock it and open it up and the white lines are gone but when the iPad cools down and I would put down the brightness, the white lines would flash back again. What do I do now? Is it an LCD issue? I just recently bought a replacement LCD from iFixit and its on its way. I wish that would solve the problem.
Did I make the right choice? Any suggestions? A reply would definitely help me a lot.
Thanks
Es esta una buena pregunta?
12 comentarios
I was wondering what the problem ended up being? I have the same issue but the problem comes and goes... my iPad has never been repaired and has no dents or cracks. One day the lines appeared and the entire screen seems whitewashed.
- de Daniel Gutierrez
i had this happen to me this weekend. all i had were lines running across the screen. I then read somewhere that one could press the ipad from the back 2 inches under the camera and it will solve the problem. i tried this and it actually worked.
- de Michelle Frendo
Pressing the back 2 inches under the camera worked on mine - I have never had an issue with mine before, and it's 5 or 6 years old!
- de lbaker11111
Honestly I had this problem for a long time then one day I just woke up and the lines where gone but great advice
- de jesa taylor
I had a same symptom about 3 weeks ago and was fixed by pressing the back. And the symptom came back 3 days ago again and I tried to fix it with same solution but got worse, more lines. This morning, however, I got the crispy normal screen of my iPad mini back. In conclusion, do not be panic for the problem, use your iPad as usual, then it will turn to normal soon.
- de CS Jang
Mostrar 7 comentarios más
