Saltar al contenido principal
Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
Preguntas 100 Ver todo
Screen starting to get ghost touches
Screen is tapping on it's own. I reset to factory and that didn't help. I left the phone off for a week and that helped for a little while but the problem came back!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 5
Agregar un comentario
1 Respuesta
This is a zenfone 2 right? if so, I need more info:
Q: When did you purchase this (recently I guess?)
Q: did you update its OS from the stock OS it originally came from?
If the answer to those 2 questions are YESes.. then you are in "luck" the issue is gonna get worse... LCD is dying due to some sort of firmware and OS incompatibility that exist with the older LCD ASUS used for the model ZE551ML.
If the answer is no, then Im wrong and I need more clues :)
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
mimimeowmeow estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 2,378
