Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guías de reparación, desmontaje y soporte para electrodomésticos de horno de pared.
Initial oven set stubborn
Our 1994 Jenn Aire 27" wall oven is stubborn about implementing our initial bake settings. When we place food inside, dial in the temperature, and then hit the "Bake" or other touchpad, we hear the usual clicks from behind the control panel, and the readout says "140" degrees to start. That's all normal. But then the entire thing clicks again and goes off. We've discovered that repeated attempts followed by hitting the "Bake" or other desired touchpad again right after the initial clicks will get the panel to say "Pre-heat On", and that often gets it working. But at times multiple hits of the touchpad button while the panel's still showing a readout is the only way to keep it on. It's very aggravating. If the readout holds for 10 seconds or so without turning off, it's usually good to go, and in a few minutes temps begin rising as designed.
I can't find anything wrong with the large control PC board. But it's vent slots are right at the top, which is below a microwave built-in above. Occasionally water and stuff has dripped down onto the vent area, so I added a diverter/shield inside the oven's top panel so anything entering via the vents were guided away from the board. So it's now protected, but has gotten pretty cantankerous about starting up. The wife had a devil of a time last night getting the oven to work.
Why does it take our settings, seem to start an On cycle, but then quit?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Joel, the clicking are the relays and your right, that is normal. Voltage applied to a relay causes a clicking sound. You should hear the bake element relay click on and in a little while click off, and then the broil element relay will click on then it will click off after a little while. This is a hard one to diagnose without being in front of the unit. I would turn the breaker off and check the broil element for a short or if its open. If its okay, I'd say to check the control board. The tests on the board would have to be done with the power on and at the time it cuts off. I'd suggest having a qualified technician with experience on that unit do the diagnosis. I hope I was of some help.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Hafcanadian estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 247
