Saltar al contenido principal
La primera generación del Nissan Murano se presentó en forma de producción para el año modelo 2003 en el 2002 New York International Auto Show.
Preguntas 19 Ver todo
How to change headlights bulb
How to change headlight bulb
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
4 Respuestas
Solución Elegida
This should help
https://www.youtube.com/watch?v=8tglvV6S...
Fue útil esta respuesta?
Puntuación 3
@bexon59 open the front portion of the wheel liner. You should see a white cap with ridges and a tab, open that. Next there should be a silver connector socket with a lighting bolt symbol, pull that off. You should now see the back of the bulb and its clip. Squeeze the clip and pull it back to remove the bulb. This video also not the best, should help you with that.
Puntuación 1
IF you open the hood of your car there should be a big black screw (somtimes plastic) if you unscrew that you can pull you head light out and disconect the wires. Then you can take off the back cover to the headlight and change the bulb.
Puntuación 0
4 comentarios:
its that way in my car
- de
@tylor_b you have a Nissan Murano?
- de
Hes got an old ford escort or some $@$*. My murano is alot more complicated.
- de
You can get to it from the inner fender, removing the front wheel well weather protector.
Puntuación 0
Añadir tu respuesta
Verland Laurent estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 32
Todo El Tiempo: 16,815
