What is the brake line diamter size going to rear brakes
2000 grand am gt need to replace brake line just cant find out the size
Es esta una buena pregunta?
Use a digital caliper to measure the OD outside diameter. Take one end off, use the other small blades of the caliper to measure the ID inside diameter of the line. Go to an auto supply and requisition the length you need, always get it a little longer than you need, you can always cut off any excess after fitting in place,
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 6
Todo El Tiempo: 767
