Why is tape/glue strip so bad?
Why is tape/glue strip so bad. It doesn't stick even after cleaning with alcohol.
Es esta una buena pregunta?
Alcohol typically ruins adhesive. Ifixit recommends replacing those strips:
Sustitución de las tiras de adhesivo del iPad 4 GSM (ensamblaje de panel frontal existente)
Fue útil esta respuesta?
I would add you need to apply pressure in one direction around as you apply the cover glass and keep it under pressure for a good 12hrs to let cure. Here's a good vid of us checking out different methods: EP65 Conclusion to the iPad Sealing Workshop at the iFixit Unconfrence
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 198
