Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La consola de juegos Xbox de tercera generación de Microsoft, lanzada el 22 de noviembre de 2013.
Controller sync button not responding.
I cannot get my controller to sync to the Xbox. When i press the side button on the Xbox it will not enter sync mode. if i plug the controller in with a USB cable it will work like normal, but the second I unplug the cable it disconnects. I have already tried a factory reset of the system and tech support wants to charge me to replace the system. any advise?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
If your wifi is still working, and assuming the controller's transmissions are working fine, it sounds like it might be the RF module. Xbox One RF Module Board
or..
Xbox One Wi-Fi Board
and..
Xbox One Wi-Fi Cable
Imagen de Replace a damaged RF module daughter board. This part is compatible with an Xbox One console.
Producto
$5.99
Imagen de Replace a damaged 802.11ac Wi-Fi board in your game console. This part is compatible with an Xbox One console.
Producto
$29.99
Imagen de Replace a broken or damaged Wi-Fi cable for your Xbox One game console with this part. This cable bundle and plastic bracket connects the Wi-Fi board to the motherboard. This is a used, OEM part.
Producto
Fue útil esta respuesta?
Puntuación 1
8 comentarios:
It connects to Wifi just fine. When I press the button to sync I can hear it click, but the console light wont flash.
- de
If you have another controller to test you might try it first, otherwise I suspect the RF module. Hope this helps :)
- de
I have tried a controller from another console with no luck. Any idea how to change the RF Module? I couldn't find anything online
- de
There is a guide right underneath the part that I listed for the RF Module :) ifixit is the best.
- de
You should also double check your settings to make sure the problem doesn't lie there.
- de
Mostrar 3 comentarios más
Añadir tu respuesta
Chad Edwards estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 19,447
