Saltar al contenido principal
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 2265 Ver todo
iPhone 7 which is dead
i have an iphone 7 which is dead i tried everything i could but nothing, i measured every single caps on the board but no short and ,also i did connect it to a power supply zero amps , but when tries to boot up it goes up to 0.06 or 0.07 ma and stays there
i was wondering if someone can help ,also i measured voltages from PMIC
all the rails have the right voltages :{
and i tried to make it hot with power supply but as the currents consuming is very low it doesn't produce enough heat
thanks for reading :)
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
9 comentarios:
did you check tristar
- de
Or batt_main?
- de
Yes i did replaced the tristar and batt_main is work well as i get normall voltages from pmic
- de
is it taking amps on the power supply without the power button being pressed
- de
hi ,no it does't
- de
Mostrar 4 comentarios más
Agregar un comentario
1 Respuesta
I also got a problem like that but i solved with by changing U2 ic.Most of the iPhone dead with by using copy charger,
Fue útil esta respuesta?
Puntuación 0
1 comentario:
i already tried that
- de
Añadir tu respuesta
yousef estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 252
