I have problem in the screen
I have laptop Acer V3-771 and i have problem in monitor :
The problem is : the output for the screen is white color.
I wont solve for this problem .
Es esta una buena pregunta?
@qutaiba72white screen means that the backlight is on but your display does not receive any data. Check with an external monitor and see if that displays properly. If it does, you know that you GPU is circuitry is working. Check the cable to your LCD and you may have to replace the LCD. If it does not then your issue is with the GPU so you will have to check on the motherboard. For that you would need the schematic
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 308
1 comentario
Thank you very much for your advice
- de Qutaiba Saoor
