Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Los modelos estadounidenses salieron a la venta como vehículos del año 2012. Los primeros modelos incluían la opción de carrocería sedán de cuatro puertas o hatchback de cinco puertas, motor DOHC de 2.0 litros (148 hp), transmisión manual de cinco velocidades o Lineartronic CVT con modo manual de seis velocidades mediante levas en el volante.
Key will not release
2013 Subaru Impreza
Key will not release when we shut the engine off. We have already troubleshot several steps. Brake is applied, transmission firmly in park, pushing key inward while turning engine off. Engine shuts off but will not complete cycle so that it can be removed.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
Hi don, is the steering wheel locked? Make sure that is can turn a full 360.
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
I had this issue with my 2016 Impreza. After pulling apart the center console, I figured out what was causing my issue.
To move the shift knob the driver needs to squeeze in the button on the front (blue circle in the picture). This lifts up a rod through the knob (red line in picture) . with the rod up the shift knob can be moved into gear. The rod also presses a button when in park, releasing the key. My issues was the rod was not dropping all the way down and activating the switch. I pulled the rod out and put some light grease on it, hasn’t been a problem since. It was not to much work to get the rod out but I don’t remember exactly how.
Imagen
Sorry its so late, maybe this will help someone else
Fue útil esta respuesta?
Puntuación 2
If it has a locking steering column, the wheel may be turned too far. Turn the key while jerking the steering wheel back and forth fractionally.
Puntuación 0
Included with the above recommendations, I depress the brake pedal while removing the key. This might help.
Puntuación 0
Añadir tu respuesta
don fagan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 37
Todo El Tiempo: 6,924
