Power supply for iMac retina late 2014
Which power supply should I buy ? Upper one or lower one ?
I linked below.
Es esta una buena pregunta?
I linked below.
Hello,
You only posted one link... This part should be good as long and you correctly match the EMC#. You can put your serial in Everymac ultimate lookup to check you current models EMC#. Opening it up and replacing the PSU is the hard part.
BTW don't forget the Adhesive strips.
[producto vinculado inexistente o deshabilitado: IF174-005]
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 799
2 comentarios
As far as I can see, those are the same part. Perhaps you accidentally put the same link twice?
- de Rachel Acosta
Are you sure you need to replace the power supply? Double check your cord is good and review the diagnostic LED's what are they telling you.
- de Dan
