Why is my screen dim
already tried changing the signal cable but its dim still
Es esta una buena pregunta?
it could be that the screen isn't being as energy efficient as it used to causing a lower max brightness, look if you can find a small flat knob that a phillips head can fit into to adjust the voltage.
Fue útil esta respuesta?
Have you tried System Restore? Or a Last Known Good Configuration?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 106
1 comentario
Have you tried changing the brightness using something like Fn+F11/F12?
- de Alex Niculescu
