Saltar al contenido principal
Lanzado el 19 de septiembre de 2014, este iPhone de pantalla de 5.5" es la versión más grande del iPhone 6.
Preguntas 1526 Ver todo
How can I check to see if power is getting to new battery after water
iPhone 6 Plus water damage. I have replaced the battery, immersed the back of the phone in 90% alcohol in an ultrasonic cleaner, dried thoroughly, reconnected the screen cables but still not getting any indication the the battery is getting power from the lightning connector. Any help would be appreciated.
Es esta una buena pregunta?
Puntuación 1
1 comentario
@dglav60 , I would suggest doing exactly what Minho suggested first. But here is a link to a video that explains testing voltages around Tigris and Tristar (After testing PP_VCC_MAIN & _PP_BATT_VCC to see if they are shorted as @refectio mentioned since you will then have the shields removed). https://www.youtube.com/watch?v=Konvdpt4...
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Just plopping the phone in an ultrasonic cleaner isn't going to help. It's better than putting it in rice but if you have access to an UC, leverage it to it's maximum effect.
Remove the logic board and remove the shields so that you can see what parts of the board were attacked by water/corrosion. This will help you with your troubleshooting later on. Then clean it in the UC. You really shouldn't put IPA in the bath though as it has a low flash point and the UC will really excite the molecules making for a hazardous situation. Ideally, you should use a cleaning solution like Branson EC and then rinse in IPA.
Once that is done, then start probing the board, specifically, check the PP_VCC_MAIN & _PP_BATT_VCC to see if they are shorted. Only then would I recommend putting a battery on. If it doesn't boot, then you have to dig deeper in the circuitry to understand what's going on.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Denny Glavin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 50
