Liquid Damage to PS4
Hello,
I have liquid damage to my ps4, what are the ways i could fix it/check which parts need to be replaced. Also how hard would it be to Do it myself
Es esta una buena pregunta?
Hello,
Have you cracked it open yet? Seeing is believing. It's hard to tell what's bad without doing so. If you want you can check your connections on the outside for corrosion first.
Alrighty.....that's some pretty bad corrosion and you have some components that are fried. I'm honestly not sure that will be a fixable project to be honest because there are so many dead parts. As soon as you start cleaning it they may fall off.
Fue útil esta respuesta?
there is no corosion
Is there anything that's not working? Sometimes cleaning your connections with a fiberglass pen will do the trick.
Heres what it looks like, i tried changing the power supply, plugged it in, heard 3 beeps but stil no lights on console. https://imgur.com/a/jxWjj
@justins21 If you heard three long beeps, this is the PS4's overheat warning.
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 1,320
i might get in trouble for taking it apart
- de Aiden Carte
