Saltar al contenido principal
Procesador Core 2 Duo modelo A1225 / mediados de 2007 y principios de 2008 / 2.4, 2.8 o 3.06 GHz
Preguntas 433 Ver todo
Replacement Microphone for EMC 2134
Hi,
I replaced my disc drive on my 24" iMac 2134 - in the process I managed to break the microphone. Does anyone have suggestions as to what would be an acceptable replacement? Does iFixit sell one? Or is it possible to repair it? Basically I removed the two wires from the circuit board. Suggestions would be much appreciated.
Thanks,
Paul
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
I'm pretty sure it's built into the camera board, you don't see the mic replaced often. If so here's the part: http://www.gainsaver.com/Catalog/Detail....
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Thank you for your response but that is a link to the camera portion. The mic goes in through a different cable which has an detachable part that when you take the top case off comes off with it. Unfortunately I destroyed the connection when I removed the case. it looks something like this http://www.gainsaver.com/catalog/Detail.... but for the Intel 24"EMC 2134. Any other ideas? Thank you
- de
I can't find the mic or the part number for it. The closest I could get is the cable part number 922-8158 & 922-8155
There a chance that a MacBook Pro mic would work. Here's one: http://www.usedmac.com/catalog/product_i...
- de
You can buy the imac bezel bc that part of the Mac comes with the microphone
Puntuación 0
Añadir tu respuesta
Paul Sednaoui estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 3,816
