I have wet Mi Note
After getting wet from rain its not working. Can you please tell me how to fix it.
Es esta una buena pregunta?
@asadul401 you will have to treat it the same way you would treat any other water damaged device. First off do not turn on, sync or otherwise use your phone. This could make a bad situation worse.
After that I would disassemble it by following these guides. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields on your motherboard. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. If you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. The best way to clean it would of course be by using an professional ultrasonic cleaning. Keep in mind that water damage is the hardest to troubleshoot and to repair
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 73
