bearings that the trackball rides on?
has anyone replaced the bearings the trackball rides on?
Es esta una buena pregunta?
Usually they just need a good cleaning with a q-tip and some alcohol.
Fue útil esta respuesta?
the ball is sloppy loose, so that ball doesn't track smoothly
sounds like the balls are in a retracted position.
Wash ball with soap n water, dry thoroughly and rub some candle wax (birthday candle) on trackball. Replace ball and move ball in holder in different directions until ball moves freely.
This was magic!! So so smooth now. I wish I had known this years ago as I love a trackball mouse.
@dakblu You are the men
There is excellent info on trackball bearing replacement in the comments of this:
https://sean-the-electrofreak.blogspot.c...
Which also refers to
Soy candle wax worked!!
UPDATE: Soy Wax got a little gunky; probably why the slick scroll didn’t last long. HOWEVER, one application of DRY OIL and the trackball is still smooth! This product is for hair and I’m sorry that I can’t recommend a more common alternative. Just in case you ever come across it: https://a.cl.ly/5zuBEBJO You only need like 3 drops
Soy wax has a very low melting point. Paraffin and beeswax may be a better wax for it. I would try a little silicone spray and polish it off before replacing the ball - I plan on trying that myself. The silicone coating should also help to keep the ball a little cleaner.
Eyeglass cleaner - the type with some kind of silicone whatever that fills in small scratches - leaves the ball and bearing-nubs almost too slippery. Sadly, wears off quickly, so flattened nubs will have to be replaced with something. Thinking maybe nylon screws, with ends filed or carved into points
Ultimas 24 horas: 3
Ultimos 7 días: 17
Ultimos 30 días: 58
Todo El Tiempo: 5,888
