The AUX doesn't work, the Jack Socket was broken
I have a Bose bluetooth speaker II, the hole of AUX was broken, how can I fix it.
Thank you very much!
Es esta una buena pregunta?
@chunxia this sounds like the AUX has come off and been pushed in. this guidewill get you to the boards. then take a couple of good pictures and post those with your question. It will allow us to see what you see. Use this guide Agregar imágenes a una pregunta existente for that. Most likely soldering a new connector to it should resolve the problem.
Guía
Dificultad:
Muy fácil
2 - 5 minutes
Guía
Dificultad:
Difícil
6 minutes
Fue útil esta respuesta?
Hi, I have the same problem: is the AUX port definitely soldered on, or is there a way to fix this issue without soldering? Thanks, Lucas
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 976
