Saltar al contenido principal
format / hard reset my tablet
Hi all , I have gone through the hard reset up to clicking on the factory reset but then I get a quick flash of green robot on his back with a red triangle , then it goes back to logo with no option for yes or no to confirm reset .... Please help me !!!!!!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Hi Carl,
I'm not sure which way you are using to factory reset your tablet but the steps I provide should help with factory resetting it successfully:
- Turn Off your Samsung Galaxy Note 10.1 device.
- Wait for 10 seconds, Then move to the next step.
- Press and hold Volume Up key + Power key.
- Keep pressing the above keys until the Samsung Logo appears,Then release Power key only.
- When you see Factory reset / System Recovery menu on screen release the Volume Up Key.
- Use Volume Down key to select Wipe Data / Factory Reset option.
- Use Power key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use Power key to confirm.
- After performing the hard reset, Select Reboot System Now option, And confirm it using Power key.
- Wait for it to be fully on and then you can start using it.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Hi Nita , thanks for your help , but the problem I am having is still there as when I get to the wipe / format the tablet , I click on it but instead of going to the yes / no option , I get a flash of a green robot lying on its back with a red triangle on top of it , and instead of yes / no the tablet goes to the loading icon and reboots automatically back to where I started ........ Please can anybody help ....... Many Thanks to Nita for your help so far ........
- de
Thanks for your help , but the problem I am having is still there as when I get to the wipe / format the tablet , I click on it but instead of going to the yes / no option , I get a flash of a green robot lying on its back with a red triangle on top of it , and instead of yes / no the tablet goes to the loading icon and reboots automatically back to where I started ........ Please can anybody help ....... Many Thanks to Nita for your help so far ........
Puntuación 0
1 comentario:
How weird! Make sure you're clicking the correct buttons or maybe having it plugged in while you do this will help. Otherwise I'm not sure what the problem could be!
- de
Añadir tu respuesta
Carl Egan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 103
