Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
Calculadora científica de Casio. Ampliamente utilizada por estudiantes de todo el mundo debido a su gran calidad por el bajo precio.
Not working. No display. Better also changed. what should I do?
My Casio fx991 es plus calc not working what should I do? No display battery also changed. Advise me please.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 22
14 comentarios
My Calculator display is gone. How can I repair it
- de Compartir
Not working properly only working solar power not working on
- de Compartir
It is not working and displaying.
- de Compartir
Not working and not displaying
- de Compartir
CASIO fx-991ES not working even though replacement of Battery. But its working with solar. pls suggest any things for resolve.
- de Compartir
Mostrar 9 comentarios más
Agregar un comentario
11 Respuestas
Respuesta Más Útil
same problem occured my casio fx-991es plus. i changed battery same problem occured not turn on my calculator but working while solar. so i opened my calculator i check the wire connection solar wires are connected properly and battery black wire it mean negative line cut down. i fixed that issue now my calculator working finely. thanking you.
Fue útil esta respuesta?
Puntuación 4
6 comentarios:
Can you please tell me How did you you fix the issue
- de Compartir
Same problem can u say me clear procedure
- de Compartir
can you please tell me in what place where the black wire should be connected? thanks in advance
- de Compartir
I had the same issue, replaced battery but still didn't work but it works on the solar panels if flashed with a light source. I opened my unit and what happened to my calcu was the black wire were slightly corroded and a with a touch it suddenly snapped at the soldered point. I soldered in back in place and it came back to life.
- de Compartir
You re lie I am calcalater man I rip all tha calcs thats what us pros call the calcualtors dont worry I can help at all points just come to address here namaste fremnd Dundrum Rd, Friarland, Dublin 14, D14 W0V6
- de Compartir
Mostrar 1 comentario más
I saw that the calculator was solar, so then I took my device and turned up the brightness and faced it to the front of the calculator. It started turning on
Puntuación 1
1 comentario:
I most likely shouldn’t have been doing my assignment in the dark in the first place ^3^
- de Compartir
As it’s screen is not showing anything; Consult with any technical expert as there may be some internal faults which can’t be solved verbally.
Puntuación 1
I bought my calculator not long ago but it has stopped working
Puntuación 1
2 comentarios:
- de Compartir
Still it is not working.
- de Compartir
@shah313 double check to see if there is a reset hole on the back of your calculator. Use a small object to depress the rest button in there. Let us know what you find.
Puntuación 0
3 comentarios:
Thanks for your answer but my calculator still at same position.
- de Compartir
I pressed the button but still, nothing happened.
- de Compartir
Thanks for ur answer my calculator start working
- de Compartir
On the back there will be a “P“ button in the middle. Press it and see if there is a difference.
Puntuación 0
Same thing also happened with my calc. So i was searching for the reset button but couldn’t find any at the back. So what i did was i tapped the calc around the solar plate area with my fingers three four times and then pressed the power button. And it turned on.
Puntuación 0
2 comentarios:
I dont know how , but your method worked :lol
- de Compartir
Worked for me as well.
Thank you
- de Compartir
I had this problem too I opened my calculator still couldn't figure out what was the problem so what I did was my cal works on solar power as well so I turned my cell phone flashlight on and I held my calc display in front of the light and it worked it's not supposed to work when I light is
Puntuación 0
Lose the calculator
Locate the power button area
Find a screwdriver and use it to scrap/scratch the power button area on the motherboard gently.
This works for me💥
Reach on Whatsapp at +2347068995770 for more explanation.
Taotech Solutions.
Puntuación 0
My calculator fall and stop working immediately
Puntuación 0
من ماشین حساب از مدل کاسیو dj-220 باتری اش ضعیف است اما من می خواهم که با صفحه ی نوری کار کند که بازهم کار نمی کند لطفا مشکل را بگویید
Puntuación 0
Añadir tu respuesta
Shahzad estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 32
Ultimos 30 días: 157
Todo El Tiempo: 50,569
