Saltar al contenido principal
Modelo de mediados de 2012, procesador A1278 / i5 a 2,5 GHz o i7 a 2,9 GHz.
Preguntas 1624 Ver todo
Replaced battery but still has low lifetime
Hey
I got today my new battery from ifixit and replaced it, everything went well. I left the mac to charge (took about 2 hours to 100% as usual) and I started using it. I only have google chrome (5-6 tabs) and vlc open my ram is 4GB.
It's been 2 hours of use and it has reached already 50% is it normal?
thanks!
Es esta una buena pregunta?
Puntuación 0
4 comentarios
Please give a history on why your replaced this battery. It's a little early for it to be failing.
- de
I got my macbook the october of 2014 and I've been using it almost everyday both for work and home use. It's been gone over 1300 charge cycles.
- de
@odysseasts - Was this a used system?
- de
No it was brand new out of the box. This is my 2nd macbook pro, the first one was the same model bought on 2010 (or 11, can't remember).
- de
Agregar un comentario
3 Respuestas
Solución Elegida
Did you follow the IFIXIT sheet that came with the battery? There is a process which you need to follow. First allowing the battery to fully recharge over night (disregard the menu meter), then you need to discharge the system and then repeat the process at least twice to set SMC correctly. At this point you'll need to reset SMC again before you do this.
I would recommend getting CoconutBattery which is a free app that allows you to see the battery & charging status.
That should fix things
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Oh thanks, no there were no instructions with the battery just the receipt.
But I'll do that. Can I use the mac will charging or it has to be turned off?
- de
Sure you can use it while plugged in charging.
- de
Here's a listing of Apple T/N's that you should review:
Here's how to calibrate your battery: Calibrating Your MacBook, Air, or Pro Battery
Puntuación 1
1 comentario:
@odysseasts - See if these help!
- de
Hi,
I have a similar question.
I just bought a replacement battery for a MacBook Air 11" 2011 and replaced it successfully. Then I reset the SMC, charged the battery overnight and discharged it the next day. The battery lasted only about two hours watching YouTube videos.
Did I mess up the process or is it the battery?
PS: I didnt get the IFIXIT sheet either.
Thanks!
Puntuación 0
1 comentario:
Review the T/N's & Calibrate links below that should do it.
- de
Añadir tu respuesta
[deleted] estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 2,077
