Saltar al contenido principal
Modelo A1502 / 2.6 GHz (Turbo Boost hasta 3.1 GHz) o 2.8 GHz (Turbo Boost hasta 3.3 GHz) procesador Intel Core i7 de doble núcleo con 4 MB de caché L3 compartida.
Preguntas 494 Ver todo
Why is my MagSafe 2 charger randomly not working?
I recently bought this used MacBook pro, and initially it worked well. Then I started noticing that the fan randomly speeds up even though the MacBook is cool to the touch. So I used a software to manually set the fan speed and it showed me 0 RPM for the fan, and wouldn't manually change the speed. I did multiple SMC resets but no change.
After some time I started using development apps like Xcode and Android Studio, and the MagSafe charger stopped working. At first I would reconnect the plug or the connecter and it would start working. But now the charger doesn't work for hours.
I use the charger when the battery is around 20%, I plug in the charger and the connector and there is no green or orange light, nor is there any reaction on the MacBook.
Then I took the same charger and connected it to my brother's brand new MacBook (2015 Model) and the light turns on. But when I use it on my own afterwards, my MacBook doesn't charge.
Then I tried my brother's MacBook charger on mine and that worked, my MacBook started charging. After about 2 minutes I used my charger and it started working as well. This has happened multiple times so far and I can't figure out what the problem is.
My charger even started working after I used it on a friends MacBook Air and then immediately on mine. That only happened once and I don't know why.
Is there anyway to figure out the actual problem? Should I get a new charger?
Also I live in a country where it's hard to find reliable persons for repairs or replacement equipment and hardware.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
First unplug the charger from the wall and turn the Macbook off.
Try to clean the MagSafe 2 contacts with a cotton swab and rubbing alcohol.
Both the laptop and the charger sides should be cleaned.
Hope this helps.
Fue útil esta respuesta?
Puntuación 2
5 comentarios:
I tried this already, didn't work.
- de
In that case, yes get a new charger. Only get an Apple charger from a real authorised dealer. Which country? Maybe I can suggest locations that are reliable.
- de
I live in Karachi, Pakistan. There is an authorised dealer here, but I want to be sure the problem is with the charger before I buy an expensive charger.
- de
@nomansaboor - review this Apple T/N see if any of the other points could be your issue: Apple Portables: Troubleshooting MagSafe adapters.
You may want to read this as well. One of the biggest issue many people face is crappy cloned chargers which are both a safety risk but also can harm your computer. While more money in the long haul you'll be better off. Here's a good write up: Lacking safety features, cheap MacBook chargers create big sparks
- de
@nomansaboor, you can take your laptop in a few times and try the ones they have on display a few times, right?
- de
Añadir tu respuesta
Noman Saboor estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 6,396
