Saltar al contenido principal
La cuarta generación de la tableta Surface Pro, lanzada el 26 de octubre de 2015.
Microsoft surface pro 4 mother board schematic help
i need the motherboard schematic for my Microsoft surface pro 4, i7
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
4 comentarios:
Hi suface not poweron iwant shcmatice
- de
Hello i need too surface pro 4 schematic (datasheet) you found?
- de
hi, could you make it 16gb ram? i have a surface pro 4 and i wanna replace the rams. how did you do that? did you need to replace resistors?
- de
Hello,
Unfortunately I haven' t got the schematic. Also for surface 1 they were not available.
But if anybody have got them, I would also take them.
But I' ve also got another question.
Is your surface fitted with 8 or 16gb of ram?
I ask because I want to upgrade my Ram from 4 to 16gb and I also ordered the necessary chips already.
These are K4EBE304EB-EGCF ones from Samsung.
But now I'm not sure whether it is necessary to equip also the marked areas in the pictures with components.
https://picload.org/view/dgrpgrdr/pictur...
https://picload.org/view/dgrpgrda/pictur...
Now my question for you is the following. If you have removed your mainboard, could you please take a look at the marked free areas in the picture and check if there are any components are mounted. And if there are should be any maybe you could take a picture or tell me what' s there because there are absolutely no pictures in the inernet.
Thank you very much for your help.
- de
Agregar un comentario
1 Respuesta
I have it, write to my email and I will send it to you. manuelbrito162@gmail.com
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Bashar Aljawrneh estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 3,544
