Saltar al contenido principal
A1706 / EMC 3071: lanzado en noviembre de 2016, este Macbook Pro de 13 "presenta la barra táctil OLED. Cuenta con una CPU Intel Core i5 de doble núcleo" Skylake "y cuatro puertos Thunderbolt 3.
Preguntas 241 Ver todo
How to Repair the black strip that says MacBook Pro
Hi I noticed something got stuck in the crack where the screen folds down. Now I have a pressure crack/ hole. can that plastic strip be replaced instead of replacing the whole screen etc..
Thanks
Julie
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
3 comentarios
Have you repaired it? I have the same problem, happened today
- de
It can be replaced. I have seen these parts available.
- de
Where can you buy the parts? I have the same issue with my 13" Macbook Air too
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Yes the chin plate can be replaced! Here’s the part: Chin Plate and here’s a guide that can help you see what’s behind it MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement
Fue útil esta respuesta?
Puntuación 1
Yes, it is possible to replace the black strip at the bottom! I’ve actually done it a few days ago and it’s fairly simple. First you need to have a source of heat and heat the bottom strip as it has adhesive on it to keep it stuck down. Once you’ve heated it a bit you need to find something to pry the strip up. You can use anything that’s thin enough to fit into the side of the strip to pull it up. I suggest starting from the corner as under the strip are a few ribbon cables for the display so be very careful! Once you’ve got one corner up just make sure to heat it up as you go along to make it a lot easier. Once you’ve got it completely off make sure you take out any remaining pieces or shards from the old strip. Then you’ll be good to place down your replacement! I hope these instructions were descriptive enough to guide you through the process :)!
Puntuación 0
1 comentario:
Oh man is this an old post. I just checked the date of when it was posted.
- de
Añadir tu respuesta
swimmer35 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 33
Todo El Tiempo: 2,801
