Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Repair guides and troubleshooting for the Sony Xperia X Compact. This is a compact smartphone that was announced and released in September 2016.
Microphone is very quiet
I replaced the screen and frame on a Sony Xperia X compact and since then when calling someone the other person sometimes can't really hear me good, sometimes it works fine and a second later it is very quiet and just doesn't work like it should.
What could the problem be? I already took the phone apart again and looked if there was any dust or something between the microphone (I hope it was the microphone, on the bottom right side of the mainboard?) and the screen but I didn't see anything.
Is it even possible to replace the microphone?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
1 comentario
Have the same Fault. Do you have a Solution found?
- de
Agregar un comentario
4 Respuestas
Respuesta Más Útil
I think you damaged your microphone when you changed your screen. You can dial the Sony test code *#*#7378423#*#* in the dialer, and test the microphone. Sony x compact have two microphone, their position is next to the headphone jack and the usb port, you can see this Sony xperia x compact teardown video, the microphone is fixed on the motherboard, it is non-removable.
If you need to replace the microphone, you need to bring your XA phone to the repair shop to replace.
Fue útil esta respuesta?
Puntuación 1
The solution is: Do not use any adhesive tape on the underside when closing the back cover
Puntuación 1
3 comentarios:
Why?? I have the same problem
- de
You will close the only path where the sound can enter
- de
Lol!!! Are you joking?? The sound go to the microphone from front panel. The flat hole communicate with both the secondary speaker and the primary microphone. Since the microphone is on the motherboard, between the front panel and the motherboard microphone hole you must put a seal that tunnels the sould.
- de
I had the same problem and found the solution. The quiet microphone problem after screen replacing happened to me because I forget to put a little adhesive (its a little black square seal with a circular hole) that creates a sort of “tunnel” between the microphone (that is on the motherboard) and the hole in the front panel. Without this seal the sould of voice does not reach directly the microphone and so the voice appears very quiet.
Look for Microphone Adhesive - 1301-7388 on google.
I moved the adhesive from the old screen and now the microphone works perfectly.
Puntuación 1
1 comentario:
You Sir deserve a medal! I believe this is for 80% of the people with this issue the problem. Only that you mentioned them, I could see these spongy-like seals. There are two of them. On the top right and of course the bottom end. I soaked them in isopropanol and scraped them carefully with a metal spudger, not to destroy or deform them. I couldn't find any other resource mentioning it, it's crazy.
- de
I think that the microphone and bottom loudspeaker are in the same assembly, maybe you blocked the sound shaft in the screen replacement?
Puntuación 0
Añadir tu respuesta
ppalfinger estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 29
Todo El Tiempo: 9,791
