Saltar al contenido principal
The latest phone in the HTC One line, simply called the HTC 10, released in 2016.
Preguntas 34 Ver todo
Can I only change digitizer and not the LCD?
Can I only change digitizer and not the LCD? My screen top layer is broken, the digitizer and lcd are fine, I don't think there's any way to change the top glass without changing digitizer and touch screen.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
You can cgange just the glass but this is not easy. In fact if you have never done this repaor before you are probably better off replacing the lcd. You can try to replace the glass but you will probably end up causing damage to the lcd therefore you you might have to get a new lcd after the glass replacement.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Thank you for this reply! I am in the same boat -glass is scratched but the screen is fine. Wondering if I should replace just the glass (digitizer) or do a combo with the screen. What makes the digitizer only replacement so difficult? I've only done screen replacements before, not digitizers.
- de
Thanks @harisahmed123 . I'd like to try this (i.e. replace digitizer only and not the whole assembly with LCD panel). LCP panel is fine (I can still use the phone) but screen cracked.
All videos I see on the HTC 10 are to replace the whole LCD assembly. You know of any video showing the digitizer replacement?
- de
Añadir tu respuesta
Mahdi Mohammadi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 635
