Saltar al contenido principal
Lanzado el 19 de septiembre de 2014, este iPhone de pantalla de 5.5" es la versión más grande del iPhone 6.
Home Flex Cable Replacement
I was fixing the batter (I have battery issues) when I accidentally bumped my phone off the counter and it tore (completely separated) the home button flex cable. I ordered a new home flex cable, but after doing some research- will I need to
A.) buy a new home button as well?
B.) will I lose my touch id function even if i keep the home button?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
hi Taylor, you must use it with your home button otherwise you will lose touch id function.
goodluck
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
If you tore this cable, you are okay with the touch id
But if you tore this cable, then you will need to buy a replacement button and you will lose touch ID but home button function will work
Puntuación 5
4 comentarios:
Great! I tore the flex cable up at the top, like the first image you've shown. I'll just be crossing my fingers until my flex cable gets here :)
- de
You are fine then, just use the original home button:)
- de
Taylor, you accepted the wrong answer ;-)
- de
@mayer at least she got an answer she is happy with ;-)
- de
Añadir tu respuesta
Taylor Fuller estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 83
