Saltar al contenido principal
iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben ser reemplazados como una unidad. GSM / 8, 16, o 32 GB de capacidad / Modelo A1332 / Blanco y Negro.
Preguntas 2397 Ver todo
Why my iPhone 4 says no service all the time?
Hello!
My iPhone 4 keeps saying there is no service even after trying every single possible way to fix this issue. I tried turning on and off airplane mode. Resetting network settings and when it didnt work I restored phone to factory settings. (deleted everything). Tried switching sim cards and also switching on/off other cellular settings.
The phone seems to know that sim card is inside as when I take it out it says No SIM and when I put it in I see No Service or Searching.
Please help me I am really desperate to get this phone to work.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
1 comentario:
could i get the IMEI number of your phone?
- de
Agregar un comentario
2 Respuestas
Maybe you can upgrade your iPhone system
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I tried, and it's saying the system is up to date. Those phones still use ios7
- de
check date & time
dial emergency in your country if u get response then check antenna
Puntuación 0
6 comentarios:
Date and time is correct even tried setting it manually, didn't help.
I will try making that call though I can get in a lot of trouble if they answer. After I have tried it I'll tell you the results.
- de
Call failed. It was quiet for most time and then showed that it failed.
- de
scan for networks manully does that return anything ?
- de
As the matter of fact it does but when I try to connect to any it says they are not available any more.
- de
It seems an antenna issue to me
- de
Mostrar 1 comentario más
Añadir tu respuesta
Reinis estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 709
