Dell Streak upper bezel loose?
The upper bezel on my dell streak is slightly raised. I assume their is some dirt under it. From reading the break down i think i can fix it but had some questions.
- Do i have to have the plastic tool to remove the upper bezel.
- Is the upper bezel glued on in any way if so will it need to be re-glued.
- Is their any possible breakage to look out for when prying it up.
Thank you for your time.
Es esta una buena pregunta?
