Saltar al contenido principal
2.26 o 2.4 GHz / Carcasa Unibody de plástico blanco
Preguntas 645 Ver todo
How to fix the thin rubber strip surrounding the front display
The thin rubber strip surrounding the front display got out.
I pushed it in, but it didn't be fixed.
Do I need to buy new display and replace it? or I can fix it?
Es esta una buena pregunta?
Puntuación 0
4 comentarios
Can you double check your system. I suspect you have one of the aluminum body models Vs one of the polycarbonate models as you have selected here. The Aluminum models use a rubber gasket
Review this listing: EveryMac - MacBook listing Once you find it post your systems URL here for us to see.
- de
http://www.everymac.com/systems/apple/ma...
My macbook is made of polycarbonate and model is 2009 late.
- de
yes,its mine.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
This model uses a plastic bezel which you can replace following this IFIXIT guide: MacBook Unibody Model A1342 Front Display Bezel Replacement. I would recommend getting this tool kit: iOpener as you'll need the picks and cards to hold the bezel way from the glue as you use the iOpener to soften the glues adhesion. While you might think you can be a little ruff in taking it off as you'll be replacing it you still want to use some care as you can damage the display if you are not careful.
Here's the replacement bezel Genuine Apple MacbooK 13" A1342 2009 2010 LCD Front Bezel
Imagen de iOpener
Producto
iOpener
$19.99
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thank you Dan. Your answer helps me a lot. I really appreciate your detailed answer.
- de
Añadir tu respuesta
Luis Castro estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 840
