Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Pantalla de 7.9 pulgadas / Modelo A1432 / Disponible en blanco o negro / Anunciado el 23 de octubre de 2012/16, 32 o 64 GB de capacidad
volume button not working
The top of the two volume buttons is stuck and doesn't work.
Are the buttons replaceable ?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Yes, you can replace the buttons or the button flex (or both if necessary). It will require that you remove the glass/digitizer to access the inside. The iPad mini is one of the more difficult tablets to repair and there are lots of "gotcha's" when re-assembling (which is not covered in the guides).
I would start by looking through the repair guide first. There is no Volume Button guide for the iPad mini but the Logic Board guide will show you how the mini is assembled and the iPad Air Volume Button guide will show you how the button flex is installed (it uses the same flex as the mini).
Take note of what tools and parts you need and then determine if this is something you want to do yourself. Otherwise, look for a repair shop that has a lot of experience with iPad mini's .
Imagen de Fix an unresponsive power or audio button by replacing the internal switches with this cable assembly.
Producto
iPad Air and iPad mini Volume and Power Button Cable
$14.99
Imagen de iPad Mini Wi-Fi Placa lógica
Guía
Reemplazo de la placa lógica del iPad Mini Wi-Fi
Dificultad:
Muy difícil
1 - 3 hours
Imagen de iPad Air Wi-Fi Cable/Botón del estuche
Guía
Reemplazo del botón/cable del estuche del iPad Air Wi-Fi
Dificultad:
Difícil
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Morgan Mark estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 3,329
