Charge port appears broken/loose inside phone
The charge port feels loose inside the phone and it is very difficult to get the cable to make connection to charge it, reminds of the old droid razor flip phone battery connecter going bad is it repairable or better to just buy new phone
Es esta una buena pregunta?
3 comentarios
Thank you for your help I'm too old and blind for soldering I'll try to send it to Motorola to get it fixed after I buy a new one, thanks again
- de Kevin
This is a "known issue" with Verizon. I know this because I have had about 5 replacements under warranty
- de sam n.
My phone started this about three years ago. Internet search found it’s a common problem with the Turbo 2. Port is poorly soldered to the board. Found a company that could repair it. They even had a YouTube video of him doing the repair. Then I found the the phone has an inductive charger, so I’ve been using it ever since. I recently had to replace the battery. Thought while I was in there I’d solder those connections myself. That’s when I realized why he was using a video microscope. The connections are tiny. There are five of them in a row and they are all in about a 3/8 inch space. I had to put on a pair of reading classes and look through the lighted magnifying glass I have mounted on my desk. I didn’t have a soldering tip small enough. In fact I’ve never seen one small enough so I wired a needle to the tip and went at it. The needle just wouldn’t transfer enough heat to melt the solder so I gave up and finished the battery install.
- de Gary Holstein
