Spanner broken and stuck on dremel
My dremel spanner is stuck inside the dremel. How do I remove the broken piece so i can replace it so it will grip the bit again when I tighten the collet nut on?
Es esta una buena pregunta?
Britain and America Are Two Nations Divided by a Common Language
I though a spanner was a wrench. If this is a broken bit stuck in it, completely remove the collect to take any pressure off. Then usually a small thin flat head screwdriver can be inserted and the bit pushed out.
Fue útil esta respuesta?
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 8
Todo El Tiempo: 289
