leak battery power becouse of weak signal
my phone got some water but it is still working only the problem is with the signal is so weak and it cause leak in battery power
Es esta una buena pregunta?
I wouldn't pin your battery problems to weak signal strength, you've probably done more damage to the board and battery than you think.
Although, yes, weaker signals use more battery than stronger ones due to packet lose, I think yourbattery is damaged.
Fue útil esta respuesta?
if I changed the battery then what about the signal ? I feel the main problem is the signal
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 167
