Saltar al contenido principal
Modelo A1278 /Procesador 2.4 o 2.66 GHz Core 2 Duo de mediados de 2010
Preguntas 794 Ver todo
Can't start-VIDEO issue MBpro 13" mid 2010
mid 2010 MB pro 13" sometimes will not FULLY power ON; sometimes it shuts down on it's own - is this a VIDEO issue that causes malfunction? How to fix short of replacing the motherboard?
Update (07/06/2017)
From cold start the unit 1) starts and proceeds approx. 1/2 way through it's sign on/up and then fails; 2) unit won't start AT ALL; 3)Unit works OK; 4) this machine was registered before the Apple deadline for taking care of this problem at the Apple store in Briarwood, Ann Arbor, MI. from where it was purchased and Apple would not take care of it. Memory works the same whether it has 4GB or haS been upgraded 16 GB RAM. Please share your ideas with me at:: walter@walter1.com.
Thank you
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
There's not enough symptoms to tell.
- de
Agregar un comentario
1 Respuesta
Have you had any screen anomalies? When it boots half way, are you getting the progress bar? Does it get to about 60%?
First I would disconnect the hard drive and attempt a boot from the original 10.6.3 installation disk or a 10.6 retail DVD. If it boots, it's the hard drive and/or hard drive cable.
If I remember correctly there was not a recall on the 13" model, only the 15".
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Toner9001 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 39
