Saltar al contenido principal
La actualización de marzo de 2015 de la pantalla Retina MacBook Pro de 13" de Apple, modelo A1502, presenta procesadores Intel Core i5 e i7 de quinta generación e introduce el trackpad Force Touch.
Preguntas 1185 Ver todo
No backlight, black screen, external monitor works ok
I use my laptop mostly with external display via displayport, but laptop always in open state(use internal monitor also).
No water or drop damage -- on half of working day internal monitor became black but external continue working. I try reset/boot macbook with keyboards shortcuts but with no success, so probably hardware problem. I use flashlight to check display and i can see that display working.
In most cases to which part of display(or whole display) this issue could be related from your experience, and from which point i need to start ?
UPDATED: i can see interface if i use flashlight.
Thank you!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
If you can see the desktop icons using a flashlight that tells us your backlight logic on the main logic board is having problems.
You either have a burnt fuse link or the WLED driver. The WLED driver is not something a DIY can do.
It might be best to find someone who does board level repair near you.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Эсарт Фардонин estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 201
