Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Un altavoz Bluetooth de bolsillo de Boomphones, lanzado en 2013.
Why doesn't my boomphones pocket speaker charge up
When I plug it in to charge the green indicator light turns on and stays solid,then about 3 minutes in the blue Bluetooth light comes on as if the power was turned on and then I pushed the power button again and the blue light went off as if I turned the power off and it will keep doing that so I just left for a few hours with both the green and blue lights on solid and when I disconnect the charging cable it goes dead and doesn't turn on like it didn't charge at all. Is there a way to fix this?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
I think you have a faulty battery on your unit. So the unit thinks that the battery is full (because there's no current flow = battery already full), and it seems that Boomphones has a software (or hardware?) bug that makes the speaker turns om when the battery charge level reaches 100%. You may want to open the speaker with my guide and check the battery voltage, it should be between 3v and 4.2v, anything other than that indicates a faulty battery.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Kelly Hunt estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 347
