Saltar al contenido principal
Lanzado el procesador Intel Core i7 de cuatro núcleos el 24 de octubre de 2011 / 2.2, 2.4 o 2.5 GHz
Preguntas 405 Ver todo
Is the sensor reading the fan speed located in the fan itself?
My left fan is working full speed (goes down to normal speed for few secs) . After lots of troubleshooting, I deduced that the computer is not able to read the proper RPM of the left fan (very low 0-200 RPM), hence it operates the fan at the highest speed as a fail-safe precaution.
Now I am wondering, if this reading failure is stemming from a logic board issue or fan issue.
So where is the sensor located? Is it in the fan itself or on the logic board?
I ran AHT and it returned 4MOT/4/40000002 left side -0
I am asking to check if I am screwed or not :), and to decide whether to buy a new fan !!
UPDATE: Disconnecting the fan from the logic board and reconnecting it again solved the issue. The fan has been normal for a week now.
I hope no one faces this issue, but if you do, try this before buying a new fan !!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
You'll need to replace the fan unit. The sensor is within the fan and not serviceable. Here's the IFIXIT guide: MacBook Pro 15" Unibody Late 2011 Left Fan Replacement and heres the part you'll need: Left Fan unit - Apple P/N 661-4952
Imagen de MacBook Pro 15" (Late 2008-Mid 2012 excluding Mid 2009 2.53 GHz) Left Fan
Producto
$39.99
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
Thanks a lot, Dan. I will buy a new fan and install it. I am very optimistic that a replacement would solve the issue, if the sensor is within the fan unit.
If you don't mind my asking, this fan is quite expensive compared to other CAD $15-$30 fans found on Amazon and takes a long time to reach Canada. In terms of quality & reliability, do you think I should stick to this unit (the one you shared), or go with those on Amazon?. I am asking because they don't have reviews and I am afraid they might fail very soon, if they have a poor-build quality.
- de
Sadly, you do take chances on Amazon. The fan maybe from a dead system and not tested. So do make sure you pay with a credit card that offers some purchase protection.
- de
Thanks, Dan. I appreciate it
- de
Añadir tu respuesta
Yahya Mowiena estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 563
