Try this first, if it fails, return it, it is covered under warranty.
1. Make sure your speaker is plugged into a working AC socket.
2. Check the connections between your speaker and the power adaptor.
3. Make sure you are using the power adaptor supplied with your speaker upon purchase.
4. If you are using a surge protector, check to see if it is working properly.
5. If you still cant get your speaker to turn on you may have a faulty power adaptor.
6. If your speaker is not charged or used within a 14 day period it with enter protection mode. Connect the speaker to the AC power adaptor to fix this issue.
7. Make sure the battery has sufficient charge to power on the speaker.
10 comentarios
Hello, I followed your instruction and,... YES!!!
So finally it works, thank you very much!!!
- de Ronald
tkx..mr. R...what steps did you have 2 follow....stay clean and safe
- de bookbundler
Thanks this is a brilliant fix!!
- de mrthomasherman
Thanks GUY WOLF! I've had my BOSE mini in a cupboard right through lockdown waiting for shops to open - then I came across this and it was fixed by the update.
- de Tim Shave
yes big problem blinking
- de mcgogord2010
Mostrar 5 comentarios más
