Saltar al contenido principal
Esta es la página del dispositivo para el Samsung Galaxy J7. El sistema operativo que viene en stock para el dispositivo es Android OS v5.1.
Preguntas 170 Ver todo
Why my phone is not charging?
I was browsing Internet, then suddenly my phone start to heat & it was increasing. Then I turn it off & after a few time connect it to charger in off mode. I saw in display that remaining 34% of charge. After 2 hours when I came to unplugged the charger I was shocked to saw that it still showing Battery 34%. Suddenly the percentage start to decreasing although it was connecting to charger. After a short time the battery percentage gone to 0% & the phone completely shut down. Now it's not charging or getting on? What can I do Now & what is the main reason behind it? Is tha a major problem? How can I fix my mobile phone as before?
Es esta una buena pregunta?
Puntuación 3
1 comentario
Hi. Im using my Samsung galaxy j7 prime. It was working properly bt suddenly it was not charging i thought charger problem but i changed many chargers not working. But if i connect in system or a laptop its charging. Wat issue is this? Can anyone help
- de
Agregar un comentario
1 Respuesta
Solución Elegida
@amitsharmin by your description it sounds like a bad battery. Start with a new one and let us know how it progresses. There is always a possibility that it is your charger, your cable or bad charging circuitry on the circuit board. Always start with the easy things like a new battery.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Amit estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 14
Todo El Tiempo: 4,980
