Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El mando (controlador) inalámbrico Xbox One 1697 se lanzó en 2015 y reemplazó al controlador 1537 y soluciona algunos de los problemas encontrados en los controladores modelo 1537. El controlador modelo 1697 incluye un conector para auriculares integrado de 3,5 mm, que permite la compatibilidad con la mayoría de los auriculares de terceros sin adaptador. Este controlador ha sido descontinuado y reemplazado por el controlador Modelo 1708.
3.5mm mic not working but can hear others.
I can hear other people but they can't hear me, when I blow or talk into the mic my ring around my profile lights up like I'm talking. I've tested the mic on other devices and works. I've tried other mics but same thing happens. It's a turtle beach headset.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
6 comentarios
Does it work on other XBOXs?
- de
i am having the same problem. i can hear everyone, but no one can hear me. i have tried the cheap one that came with it, the newer one that uses the new port, and a Turtle Beach XO3. i am fearing it is my controller.
- de
It's not the controller because I have a brand new controller and headset and still have this problem.
- de
So, any answers for this problem?
- de
@dtr20 by "Ring around the profile" do you mean you are using this on a PC with discord? If so, I'd check your discord settings first, because if discord talk indicator is lighting that probably means audio is reaching it. If you are not on PC, please explain what you mean in the comments below.
- de
Mostrar 1 comentario más
Agregar un comentario
4 Respuestas
Respuesta Más Útil
Check your settings to see if your microphone is set to mute or the gain is really low. That should fix your issue as your xbox is definitely picking up audio but is not sending it to people at a high volume.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
The Xbox is not recognizing that it's even plugged in.
- de
Do you have another controller to test your headphones with? You could just be unlucky and got a defective controller.
- de
I'm having the same issue. 3.5mm jack, brand new control and turtle beach headsets for the Xbox one. I can hear others, they can't hear me. I'm not muted, all my settings are correct, and others are even hearing themselves but not me.
Puntuación 0
1 comentario:
Any answers to this? Really frustrating
- de
I’m haveing this problem also
Puntuación 0
Try going to settings, accessories, and see if your controller needs an update (very weird I know but worked for me with this issue)
Puntuación 0
Añadir tu respuesta
Jake Amato estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 29
Ultimos 30 días: 139
Todo El Tiempo: 24,495
