Saltar al contenido principal
Modelo A1502 / 2.6 GHz (Turbo Boost hasta 3.1 GHz) o 2.8 GHz (Turbo Boost hasta 3.3 GHz) procesador Intel Core i7 de doble núcleo con 4 MB de caché L3 compartida.
Preguntas 494 Ver todo
Will not charge, no charging light on magsafe?
Hi, I plugged my MacBook into a friends aftermarket power supply, and when i returned home there is no light when plugging it onto a real magsafe charger. Tried using a different charger, resetting SMC.
Also if I plug the magsafe into a different mac and then into mine, the light is orange but slowly goes dimmer until it goes out, and doesn't charge the mac.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
I was having that problem. I had several after market power supplies an very slowly my MacBook Pro stopped charging. I would wiggle the MagSafe a little and the amber light would come on the start charging but it got worse and finally I decided to change out the upper case. I SO didn’t want to pull my Mac apart but I finally did.
Do you know what fixed the issue?? A half hour replacement of the MagSafe DC in Board part. I bought a used one off of Ebay for $8 and used the iFixit Guide and it was all better. The amber light came back on with ALL the after market power supplies I owned. I was SO thankful. Try it. You will see
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Chris estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 3,267
