Saltar al contenido principal
La PlayStation 3 Slim es la segunda versión de la videoconsola PS3 con el número de modelo original CECH-2000. Producida por Sony Computer Entertainment, solucionó muchos problemas de la Playstation 3 original (gruesa). Salió a la venta el 1 de septiembre de 2009.
Preguntas 453 Ver todo
Help opening PSU cover?
I've opened up the PS3 and I want to open up the PSU unit, but I don't know how to get the plastic cover off. I've taken the screw out the bottom and I've pushed the latches at the back so the back opens up a bit, but it stays shut from the front, are there other thing I have to do?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
Step 13 of our PS3 Slim teardown denotes the PS3 slim power supply. I think there are several retaining clips in front preventing the power supply cover from opening. Other than that, it should come right off.
Fue útil esta respuesta?
Puntuación 1
Had the same issue; in my case there were no visible tabs to push back. After tinkering and pensively forcing it open, I realized that the tabs were hidden internally. Out comes the screwdriver, and after popping the 3 tabs on the vent side, the back vent is one whole tab that holds the 2 pieces together. That takes a while to open.
Hope it helps.
Puntuación 1
Añadir tu respuesta
Ryan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 26
Todo El Tiempo: 10,560
