Saltar al contenido principal
Procesador de 1.4GHz o 1.6GHz, SSD de 64GB o 128GB.
Preguntas 160 Ver todo
User upgradable RAM for 11 Inch MacBook Air
Can I upgrade my 2 GB of RAM on my new (late 2010) 11 inch MacBook Air?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
5 Respuestas
Respuesta Más Útil
Hi, According to the included link the ram on your machine can only be upgraded at time of purchase. Sorry.
http://www.everymac.com/systems/apple/ma...
Fue útil esta respuesta?
Puntuación 4
The SSD is secured by a T5 Torx screw. Do NOT try to unscrew it with a T6 or you will thread it. I almost did that since I read somewhere you need a T6 Torx screwdriver and this is INCORRECT. I bought a T5 since it wasn't in my toolkit and that is indeed the correct one. T5. Make note of this.
Puntuación 1
It looks like they say SSD is not changeable but in reality it is. Maybe the same thing works with ram?
Puntuación 0
The ram is soldered to the motherboard. When you remove the SSD, which is secured with a t6 torx screw you can clearly see the memory modules. The modules are spread out on the actual logic board rather than a removable memory module.
The 2011 model moves the memory to a new location however it is still soldered directly to the logic board and is not removable.
Puntuación 0
yes you can easy
Puntuación 0
Añadir tu respuesta
rickdesigndad estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 19
Todo El Tiempo: 19,386
